00 Center Console
Old 08-10-2004 | 03:53 AM
In9....5Coupe's Avatar
In9....5Coupe
Default 00 Center Console
I wanted to know if the center console(Ac,Heater,etc) of 00 will plug n play into a 97? Do i need to change the whole dash boared? Also can the Si cupholder + shift boost fit into a 97?
Old 08-10-2004 | 04:24 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
not plug and play. you need to replace the heater selector box and blower under the dash. you also need to replace the vent trails.
Old 08-10-2004 | 06:37 AM
In9....5Coupe
So I should just change the whole dash boared!? What about the the Si cup holder + Shift boot is that plug n play?
Old 08-10-2004 | 07:51 AM
bustah49's Avatar
bustah49
Mr. Motorhead
just use the whole console....and you have to remove the dash to convert your heater controls...as for the 99-00 are controlled electrically
i have already done that..it is not that bad of a job..TAKE YOUR TIME...
