Anybody done an F series swap?
Originally Posted by /^Blackmagik^\
the vtec F22a1 has 140 Hp i think.
some of the other possible engines would be the f22a4 from the 90-91 EX accord or the f22a6 from the 92-93 EX accords. Both are rated close to 140HP.
The f22b1 is the VTEC SOHC engine from the 94-97 accords @ 145HP from the EX
the f22b2 is the non vtec engine from the 94-97 accords, which is very similar to the f22a1.
The of course you have the f23a1 from the 98-02 accords.
These engines can usually be had for just a couple hundred bucks so that is why I thought someone might have played around with them and put one in a civic. I guess they haven't.
there is an f20b motor out of 97-00 type-r/euro accords that would be worth swapping they have 200hp and 145lb/tq w/ 11:1 compression. they are very hard to find and are expensive. imo i think an f22 swap would be point less they only have 140hp and 130lb/tq. it might be a good idea if ur planning on putting a turbo on it. f22's come out of 90-95 accords and 92 base model preludes. an h22 would be way more worth it.
Originally Posted by hybridhondahatch
im helping do one next week actually. yes its just like an H series swap.
the swap is more common on accords, but it'll fit in just like an h-series.
If it was up to me, I'd use an H23A before an F22*.
