need help here with a brake prob guys....please help me.
my brakes in my hatch just don't feel the way i think all wheel disc should. are there any differances between the 97civic dx hb and the 2000si master cyl and brake booster?
i am still using my factory hb master cyl and brake booster. please give me some help?
swap in a integra master cyl and booster and the pedal will firm right up. :thumbup:
I believe the Si/96-00 EX ones will work too... Just be sure to get a MC and booster that match (i.e. either both ABS or both non-ABS)
:edit: and it will be a little easier if you use the non-ABS booster and MC. The ABS MC requires that you re-bend and flare one of the brake pipes... kinda a PITA.
Originally Posted by bustah49
i have the 00si mastercylinder and booster in the basement...your saying that i need to use that right?
Is it an ABS or non-ABS master cyl?
fabulous... just bolt that fukker in and you'll be set.
:edit: and since you need to flush the fluid anyway, I'd reccomend going with a quality DOT 4 brake fluid as well with this swap. I've managed to cook the brakes a few times in VX w/ teg 4-wheel discs.
meh, I guess you don't really need to... I flushed because I was pretty certain I had gotten some dirt into the lines and I had a full new bottle of fluid anyway h: I'd still recommend the fluid upgrade though
Xymox007
11
01-06-2004 01:38 AM
andrew ef
06-24-2003 03:14 PM
