Crank Pully, Un-Balanced, Problem?
Originally Posted by westcoaststyle
Ya, but you were just daily driving weren't you Andy?
Running925 says he'll be running very high hp numbers and I'd assume high RPMs which is where balance is critical. Replace the pulley, it's cheap.
i notice some weird vibrations at around 2500 rpm when i had my ctr n1 pulley on my motor. i feel the balancing is def. an issue to address. i don't understand how the pulley is a big issue while the fly wheel on the other end is not.
any insight?
any insight?
any insight?
any insight?
I'll be doing it again with the new build. I just don't see spending all that money and then seeing it go down the tubes because of a small detail that was overlooked.
I see the entire rotating assembly to be an issue. I had clutch, flywheel, crank, rods/pistons, and crank pulley all balanaced up to 10k RPMs. h:
How did u have it balanced??
Take your block, main caps, endcaps and all that I mentioned to a machine shop that's equipped to do it.
Humm.. sounds like a plan.. i might have to go do that. I
I just located a machine shop thats able to do that & they are only 10min. from my house!
so let's say. we take all the rotating assembly from the short block, and i put on one of those super light unorthodox racing crank pulleys, and have my engine balanced. would you say the issues that are a part of the unorthodox crank pulley will be solved?
