D-series Si trans grinds when
My Si D-series trans grinds only when shifting from 2 to 3rd at higher Rpms and I hope its just my clutch not the syncros and also I just changed the fluid in it and when it does this it does'nt want to go into any gear even when i slow down or stop and so when I put it in 5th when i am stoped then it will go easly into any gear. What could this be other than the Clutch????
any help is great h:
How do u drive the car?? Do u shift easy or hard? If hard it prob. gonna to be your syncros. you could replace the fuild with some GM syncromesh and see if that helps. Mine use to grind a little and i replace the fuilds with the syncromesh and it seems to helped. HIH
Ok what do I have to replace?
