my EG is a curse
Old 03-09-2004 | 03:22 PM
supermac88's Avatar
supermac88
not OG but Old School
what kind of tranny are you running by the way it could be your gearing???
Old 03-09-2004 | 04:48 PM
jdmitr's Avatar
jdmitr
gearing might come to play. I have the GS-R tranny bolted on. Gears are considerably longer but I thought it would help at freeway speeds. Anyways, I can't figure it out. The only thing I can think of is that it's running too rich. Because I notice now every morning, my engine doesn't rev up to 2000 rpm like it use to and slowly drop below the 1000 mark. And I can smell raw gasoline while it's warming up trailing it's way into the house while I'm brushing my teeth. Talk about carbon monoxide poisoning!!!!!!! But running too rich will only bog the engine at low speeds. At the high rpm I was running last night, I don't see any issue of rich mixtures coming to play.
Old 03-09-2004 | 05:41 PM
supermac88's Avatar
supermac88
I don't know what to tell you man, it should be more impressive than you are saying it is.
Old 03-10-2004 | 05:44 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
if your wheel hop is really horrible maybe you should try getting traction bar or something, in the end wheelhop will kill your mounts as well as make ya slower.
Old 03-10-2004 | 06:47 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by drew935
know that the eg coupe is not as light as the hb. It weighs about 200-300 pounds more. The type s is essentially a bigger engine so should pull away a lil bit on the high end with 1.8l vs. 2.0l. Also, the engine has DIS were our engines are running the distributor. There could be some other factors not being recognized here also, like the mods on the itr engine.
coupe is about 50-75 pounds heavier than the hatch and the sedan is about 50 pounds heavier than the coupe....no 200-300 pound difference brotha :slap:
Old 03-10-2004 | 06:59 PM
cashizslick's Avatar
cashizslick
Originally Posted by supermac88
Is it a Type S you never specify, I don't think that the type S should be able to hang with a ITR powered EG.
Well, it does displace more . . .
Old 03-10-2004 | 07:00 PM
cashizslick
I think you need to have your car tuned bro.
Old 03-10-2004 | 07:45 PM
supapoopa's Avatar
supapoopa
Nissan: Shift_Recall
damn, that sucks. Is it a dx coupe or ex? Could be the change in transmisson since everything but that is the same setup from the DC.
Old 03-10-2004 | 07:55 PM
supermac88's Avatar
supermac88
true engine wise but the RSX-S weighs quite a bit more than a 95 coupe, I mean what are we talking here 5 hp. The weight more than makes up for that.
Old 03-11-2004 | 12:16 AM
jdmitr's Avatar
jdmitr
Actually I never touched the tranny, it still is the same setup. As for your question, it's an EX coupe. But it's totally strippped out. I have pics. Let me upload them.
I think you're right. Either that or buy an new computer. My friend gave me a theory that since I rolled the integra over, it probably damaged the computer bouncing around, so it might be just the brains making the engine run stupid.
