Civic Rear Disc Question
Old 02-27-2004 | 08:09 PM
93civicsedan's Avatar
93civicsedan
westcoaststyle let me know how it goes with the e-brake cables once you test it out.
Old 02-27-2004 | 08:21 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Might be a bit before I do it. I still have to have my lines made, but that's all i have left.
I also need to figure out what brake lines to use for my GSR MC/booster and Civic Si (5th gen) prop valve.
I may very well do a DIY on it. :yes:
Old 02-27-2004 | 08:26 PM
qtiger's Avatar
qtiger
Originally Posted by westcoaststyle
I've been told that the GSR (coupe) cables will work on my car.. .:thinking:
I'm hoping so. I have a complete GSR rear suspension in the garage. h:
Old 02-27-2004 | 08:43 PM
westcoaststyle
I have a whole GSR in my garage. :db:
I'll prolly do some work on it tomorrow. We'll see what all I can get done.
Old 02-27-2004 | 08:46 PM
qtiger's Avatar
qtiger
I used to. :happysad:
When you swap the GSR suspension, make sure to use the Civic springs or you'll be 4x4ing around like me. h:
Old 02-27-2004 | 09:27 PM
93civicsedan
K great a DIY would be alot of help. Just curious why do you need to have your brake lines made?
Old 02-27-2004 | 09:29 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
so wait....
if you have abs and want to do a brake swap, will you still retain abs? :thinking:
I was lead to beleive you can.... This thread is giving me the opposite impression from that second post...
Old 02-27-2004 | 09:38 PM
93civicsedan
Im not really sure if you will retain abs, maybe someone else can answer that question. I do know that if you dont have ABS you can still use the ABS parts and just get rid of all the sensors.
Old 02-27-2004 | 09:41 PM
93civicsedan
Anyone happen to know what the difference between the GS and the GS-R suspension? So far ive noticed that the gs lca has a slight curve which the gs-r doesnt have. anything else?
Old 02-28-2004 | 04:31 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally Posted by 18secFerio
so wait....
If you have ABS, you've already got 4 wheel discs... hence, theres no point in swapping the brakes
Quick Reply: Civic Rear Disc Question
