03 Civic knocks on cold startup
Old 02-16-2004 | 04:19 AM
lubedawg's Avatar
lubedawg
Default 03 Civic knocks on cold startup
My 2003 Civic (1.7L) with 23K miles has started knocking briefly on startup on very cold (20 degrees or colder) mornings. I starts and runs ok for 3 or 4 seconds, then makes a knocking sound for approx 5 seconds and then the sound fades away and it runs fine. It sounds like it's more than a lifter, perhaps a rod? The frequency is 3-5 times per second.
I'm running Amsoil synthetic 0W/30 with a Mobil1 filter and this started shorlty after I switched from Amsoil 5W/30, but that's also when the really cold weather started.
Old 02-16-2004 | 04:45 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
It wouldnt be a rod, they dont make that kind of sounds. If anything it sounds like your lifters ticking. Have you noticed any oil loss?
Also, I use a thinner oil for the winter, my car usually starts easier with it.
Old 02-16-2004 | 04:47 AM
vassil3427's Avatar
vassil3427
I would take it in under warranty, maybe try switching back to some 5w20 synthetic.
Old 02-16-2004 | 12:08 PM
lubedawg's Avatar
lubedawg
Actually, the noise is more of a rapping sound, like the sound you hear briefly after changing the oil on some cars if you don't pre-fill the filter with oil.
It's strange, because it runs fine for several seconds, then makes the noise.
My guess is oil starvation of some sort, because the noise fades away slowly.
It sounds like it 's more than a lifter - isn't that usually more of a lighter ticking sound.
No oil loss, either.
I'll give the dealer a call and see what they advise.
What's Honda's stance on synthetic oil?
I know they want you to use genuine Honda everything in their vehicles.
Old 02-16-2004 | 02:47 PM
vassil3427's Avatar
vassil3427
I do believe in the manual for the civic it says using synthetic is fine and wont mess with your warranty. However I do believe its supposed to be the same viscosity(5w20 in your case).
Old 02-16-2004 | 03:33 PM
Hondaman's Avatar
Hondaman
Black Pearl
Isn't Amsoil guaranteed not to void your warranty?
From http://www.amsoil.com/frequent.htm#warranty
Will AMSOIL Motor Oils void the warranty of a new vehicle?
Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty.)
egjoe
11-11-2004 04:16 PM
Cashis EG8
08-30-2003 06:39 PM
jaje
News & Rumors Archives
19
03-26-2003 03:58 PM
hyperlite
Engine Swaps, Tech & Tuning
7
01-29-2003 08:19 PM
jaje
17
06-27-2002 03:16 AM
Quick Reply: 03 Civic knocks on cold startup
