another 'what would you do' question!
Old 02-15-2004 | 07:01 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Default another 'what would you do' question!
Hey guys, got 620 bucks, need to know what I should get... b16a2 engine.. I was thinking of a pair of stage 2 cams.. anyway your input is appreciated, thanks <^_^>
Old 02-15-2004 | 07:06 PM
Civic2Scooby's Avatar
Civic2Scooby
what all do you have done?
Old 02-15-2004 | 07:07 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
just the swap at the momment.
Old 02-15-2004 | 07:10 PM
Civic2Scooby
well if you do stage 2 or spec b cams you will have to upgrade your valve springs and retainers...also it is not required but to get the most out of those types of cams it is recomended to get it tuned with adjustable cam gears....you will also see much greater gains with the stage two cams with higher compression......sooooo long story short just wanted to let you know some info
Old 02-15-2004 | 07:11 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
I was planning to try to get the adjustable cam gears as well. Thanks for the info.
Old 02-15-2004 | 07:15 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Very true :goodjob: I would recommend doing some suspension mods or something since you really can't do alot to the motor with $620. If anything get some type R cams or some stage 1 cams so you will not have to change your valve springs and retainers and get some cam gears so you can tune them.
Old 02-15-2004 | 07:16 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
well if worst comes to worst ill just save up more and not get anything right now =D
Old 02-15-2004 | 07:17 PM
Civic2Scooby
that is why I got the CTR cams to put in in the spring....you are still supposed to put in stiffer springs if you plan on raising the redline though. I also would recomend suspension work if you need it, or maybe a nice exhaust system, high flow cat....I dunno....but you need more loot to really tear into the head and make it worth while
Old 02-15-2004 | 07:22 PM
Civic2Scooby
but if ya jus gotta have em I would recomend these
here
Old 02-15-2004 | 07:28 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
I personally would go with some Skunk2 cams www.Skunk2.com :yes:
Quick Reply: another 'what would you do' question!
