195mm azeni are still plenty sticky :yes: I think oc got it... if the tires aren't flat to the ground, they'll spin real easily.
werd you can put some slicks on your car... if you have shitty camber you will STILL spin... a tire can only provide added traction if there is a good solid patch in contact with the ground..
