engine? blown up? what?
#31
Originally posted by Xplicid01
if u decide to get nething other than the ls motor, u would most likely have to do a disc coversion to the rear wheels. for the b18b u might be ok with drums in the back.
#33
Originally posted by hoophype84
i dont see y it would cost 500-1500 to install..the mechanic that was checking on my car wanted $300 to take the engine out of the car..i would assume taking an engine out of a car has the same steps as putting an engine back in a car..hence, it should be $300 to screw in the bolts or whatever...ugh! i horrendously dislike mechanics...usually.
ya but they hhave to re-wire everything.... and put in new motor mounts... if sounds easy.. but if u dont know what ur doing its a pain in the ass
#34
i was under the impression that the stock motor mounts, for my civic, are used? actually, pretty much all the stock stuff is used...since this is one of the easiest swaps? also, if i get the b18b, i dont have to worry if i get an "automatic version".....is there an actual difference in the engine between auto and manual?
#35
the motor nothing.... its the tranny.. i dont think u can use the stock mounts... ooo we didnt say the easyest... this is the cheaper swap....so i dont think u can use ur stock stuff....b18b is an Integra LS motor..
#36
so could i use my stock auto tranny for the ls motor?...well, i guess the board is right, none of u did say it was easy, but other reference websites say it is a 1 out of 4 on dificulty and they say that u can use the stock stuff?.....JLAUDIO..u find a price yet from yer miami friends' dad?
#37
click me!!!!!!!!!!!!
ok, so if i were to buy this motor, which i think i am going to...what else would i need, is this an acceptable motor...nice platform correct? what does the fact that it says long block mean?
#38
means that just the motor.... i just talked to my friend his wantin on a call about my motor..and hes going talk to him about a b18b tranny(auto) and ecu...(he said there out of stock... but hes checkin on sum more for ya)
ur still going to need wrieing harness, motor mounts,
** u went to HIN wheres a pic of ur car... my friend gos there alot... ill see if hes seen ur car**
#39
