How much transmission fluid to fill tranny?
I'm made of meat!
Servicing the transmission takes a little less than filling a totally empty one. Just like coolant systems, and engine oil.
1.5qts if you're just servicing it, and 1.8-1.9qts if it's a bone dry transmission.
I'm made of meat!
If it's a copper crush washer, you can get them at Lowe's or Home Depot in the plumbing section. If it's an aluminum washer, I've block sanded them with 400 grit, and re-used them (as long as they weren't distorted to start out with) and never had any problems.
Edit: My local Pep Boy's has them on the aisle with the HELP products. Most auto parts stores should carry them, too.
