B- series motor question
Old 11-19-2003 | 07:20 PM
xero's Avatar
xero
Default B- series motor question
so I have a 92 civic with a B18B swap... I have rebuilt the motor completely and am looking to add boost before it is all installed...
question? - so is the exhaust manifold sizing the same on a civic B16 and integra B18?
reason for this is question is that turbo kits I have seen specify "h", "b", "k" series ... but dont always specify what "B" series motor its designed for.
Help is greatly appreciated,
XERO
Old 11-19-2003 | 07:52 PM
Nelson's Avatar
Nelson
Administrator
The B18 E.M. should slightly be taller.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 11-19-2003 | 10:02 PM
xero's Avatar
xero
Old 11-20-2003 | 12:01 AM
Kai's Avatar
Kai
Rotorphile.
If you are building a custom turbo setup, it doesn't make any difference at all. You'd still need a custom downpipe anyway, and that would make up the ~9mm difference in deck height between the B16A pattern blocks and B18A pattern blocks.
Old 11-20-2003 | 10:08 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
The b16a would use a shorter manifold. You can use the b18 manifold on the b16 but not the other way around. The b18 manifold on a b16 would just hang lower.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old 11-20-2003 | 01:04 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
thats true for regular n/a headers, but he's asking about turbo exhaust manifolds.
Any turbo exhaust manifold for B-series will fit. Once its on and put together, just get a downpipe that will clear the bottom of the motor, as Kai said.
Old 11-20-2003 | 10:59 PM
xero's Avatar
xero
Great you guys rock, what about a greddy kit .. there are several i have seen but almost all of them say specifically GSR B18C with this work for my LS application? exhaust manifold only
Old 11-20-2003 | 11:03 PM
Kai's Avatar
Kai
Rotorphile.
Manifold only? Sure.
