Hid With Projectors
Old 07-23-2002 | 07:03 PM
derf's Avatar
derf
Spec5
sorry i was talking about the aftermarket cheap ones
how are they mad differently? due explain. no flaming on HAN rite guys?
Old 07-23-2002 | 09:17 PM
PatrickGSR94's Avatar
PatrickGSR94
I'm not a n00b!
Originally posted by EliteAccord
Halogen projectors suck:thumbup:
wrong, H3 bulbs suck, and therefore projectors that use said H3 bulbs also suck.
Projector housings really do an excellent job of putting the light where you need it, and minimizing it where you don't, provided you have a bulb that puts out a good amount of light w/ a good beam pattern (as 9006 and 9005 bulbs do, which is what Integras use).
Tony the Tiger retrofitted Audi HID projectors into his stock Camry headlights, which have fluted prismatic lenses. They seemed to work well, but those headlights also have separate high and low beams, so he was able to retain the high beams. If you put Audi projectors or the like inside Civic headlights, you won't have high beam capability, which means you would not pass inspection if it is required in your city or state.
Old 08-04-2002 | 12:04 PM
iNteGraz92's Avatar
iNteGraz92
forever lurking
what if you put them in aftermarket projectors? don't they have a separate hi/low beam?
Old 08-12-2002 | 11:28 PM
Illusion-Lighting's Avatar
Illusion-Lighting
Illusion Lighting
Here are the facts people:
ALL OEM HID headlights are 4300K. The difference in color you see between different manufacturers comes from the optics of the housing. All these 6000K, 8000K, etc. kits are purely for cosmetic purposes only. If you want that you might as well not waste your money and just buy some ghey blue halogen bulbs instead.
Projectors that use H3 bulbs suck because of the transverse (sideways) filament in H3 bulbs. H3 bulbs themselves have a crappy beam pattern.
HID capsules inside an aftermarket Civic projector housing will NOT melt anything, as it only draws 35W, compared to 55 or more for H3's. Add to that the fact that the light is generated by an arc of current, instead of by heating a filament.
I cannot say what the beam pattern and output would be like for a xenon capsule made to replace an H3 bulb, inside a projector housing. If the capsule was designed correctly with the arc the correct distance back from the cutoff shield, the beam pattern might actually be better than with halogen H3 bulbs, but who knows if engineers who made these capsules took the time to do this.
If you really want the BEST light output, you will need to hack open a set of projectors and try to retrofit in something like Audi S4 HID projectors. That's probably big $$$$ though.
right on the dot! optics is everything
Old 08-12-2002 | 11:29 PM
Illusion-Lighting
Illusion Lighting
use a bi-xenon projector if you're worried about not passing
Old 08-13-2002 | 08:08 AM
Nelson's Avatar
Nelson
Administrator
Bi-Xenon? If I'm not mistaken, only BMW makes those... and those are $$$
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old 08-13-2002 | 11:42 AM
Illusion-Lighting
Illusion Lighting
There are a few other cars that have bi-xenon avaible as an option now. I have a set sitting around waiting to be installed if someone wants to buy them off of me
Old 08-13-2002 | 12:42 PM
derf's Avatar
derf
Spec5
bi-xenon as in 'dual' beamed one? like high/low in one rite?
i know groupbuy had one for sale for $500 or something
Old 08-13-2002 | 06:30 PM
Illusion-Lighting
Illusion Lighting
yea the projector i have does both hi/lo w/ 1 bulb
ironscepter
06+ Civic/CSX
02-03-2008 05:44 PM
whiteblazer01
Accord
15
09-08-2004 08:39 AM
Riken
12-12-2003 12:06 PM
EliteAccord
92+ Civic/EL & Del Sol
19
11-13-2003 01:58 PM
switzltek
2
06-02-2003 10:14 PM
Quick Reply: Hid With Projectors
