My KYB AGX's came in today and I have a question...
I know he's done with his install but to reiterate what others have said and for anyone else who's wondering...
You should use a compressor for the stock strut/spring to take it apart... yes you have to take it apart to get the pieces that you will reuse(i.e. spring collar, strut boot/dust cover, etc.) unless you have new parts to replace them
You can take apart the stock damper assembly(strut/spring) while it is still in the car without a compressor though by placing a jack under the knuckle/spindle... jack it up a bit to compress it.... let off the nut on the struts piston shaft... then slowly let the jack down... voila... unbolt everything else... disassemble your damper and save the collar and boot for your new damper assembly
The new strut and spring can be compressed by hand if it needs to be compressed at all to reassemble it with the collar and boot from the old stuff... most of the time the new springs since they are lowered don't really need to be compressed to get the collar and nut over the struts piston shaft.:thumbup:
Re: My KYB AGX's came in today and I have a question...
Originally posted by 1994 del sol si
first off i just wanted to know what i should set the shocks to 1-4 1 being softest and 4 being hardest.I just want it for normal everyday driving what setting would be best i will be putting these on my nuespeed race springs 2.25 drop in the front and 2.0 in the rear.thanks in advance
Originally posted by sohc whore
so he doesnt need anything off the stock setup? yeah, thats what i though
these questions you ask are simple non complex questions, which have been asked many times before you decided to come to this board. we have a search function for a reason, for noobs to SEARCH FIRST.
:slap:
to everyone else: i did get all the shocks installed.I didnt need a spring compressor.I set them all on 3 but its still a little bumpy so i figure ill try it on 2.Although i know the ride wont be that smooth since im lowered as much as I am.
If the car is bounces excessively after you hit a bump, then you'll actually want to turn up the rebound compression. Go ahead and try the higher settings as well as the lower ones to see if it helps at all.
If the the ride is just harsh and jarring, then most likely your springs are just too stiff for the road conditions. From my experience, Neuspeed Race springs are stiff but not too bad so you'll be ok. I don't know how much the adjustment knob affects compression damping on the AGX shocks but if it's significant, then yes, turning it down could be the answer...at the expense of rebound damping. That's the problem with single adjustable dampers IMO.
Another possibility if your ride is simply harsh is that you might just be running out of suspension travel too soon. You might want to consider extended spring perches like those made by Ground Control. You can get them custom made if you wanted to also. I had mine done by Benen.
Good luck and enjoy the shocks.
Originally posted by NoRiCeHeRe
This true that for safety measure's you should use a spring compressor. I had "assumed" that he had all he needed (strut boot, dust cover etc..) So I couldn't figure out why he would need to compress the spring to get the shock out. It was my bad for assuming.
Sorry I couldn't resist using a little corny humor.... I assumed you knew and that's what you meant when you posted... but just wanted to clear the air for others who may not know. :thumbup:
