need LS swap advice...
These are the wheels I put on the GSX. The GSX looked exactly the same with them on. The trim on both cars is identical. I'm running 50 series on them now, though. 45's looked stupid without a drop.
This might help you get it in there pretty easy.
http://www.hasport.com/Products/Moun...unt%20EGB1.htm
I had an FC, I sold it to buy a VW :doh:
You can make that work for cheaper than you can get a B18B swap for around here.
Originally posted by Jafro
I just hope I can put it in my hatch without having to spend $500 on mounts. My civic has solid shift linkage. Couldn't I just mount the cable shifter in place of my civic shifter?
You're not quite understanding the difference between a cable and a hydrolic transaxle. The shifters are solid bars on all D and B series engines, so if you use a 94-01 Integra shift linkage, all is fine. Bolt it on and go. The difference is in the clutch system, pre-94 Integras and pre-92 Civics use a cable to engage/disengage the clutch. 94+ Integras and 92+ Civics use a hydrolic system to do the same. They can be swapped, but it takes some special mounts that HASport makes.
http://www.hasport.com/store/EGB1.htm note the "cable transmission" kit, $225. It is availible seprately from the complete mount kit.
Oh... Oh yeah... duuuuuuh.
I'm not used to cars with cable-actuated clutches. All of mine have always been hydraulic. My GSX uses cables for the shifter. That's why I got it confused because that's what I've had my head buried in all week.
I'm learning....
I'm learning....
Yeah, over on the Honda side the 90+ Accords and 92+ Preludes use cable shifters. That is one of the little things that make H and F series swaps into a Civic or Integra a little bit more difficult.
I've seen a 1G DSM shifter assembly, those things don't look very fun at all.
Yeah, one of my friends told me" Man, why didnt you just tell me you were going to get a VW, I woulda just kicked you in the nuts and got it over with"
I'd say do it. A little extra effort, but still gravy. If you change your mind, I'll buy it from you.
