92-95 Si rear trailing arm same as 94-01 teg trailin arm?
Old 10-27-2003 | 01:41 AM
Outxider's Avatar
Outxider
X-Motoring
Default 92-95 Si rear trailing arm same as 94-01 teg trailin arm?
my rear right trailin arm is bent and i found a set of itr trailin arms from a local guy, and was wonderin would my hub fit onto the teg trailin arm? bascially if i can confirm it fits then i would wont have to go to a junkyard pull one off. i check the part numbers for the teggy trailin arms 94-01 they r the same itr/gsr/ls. just wonderin if my si hub w/ my rotor and caliper will fit it. thanks for any help.
Old 10-27-2003 | 06:40 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Good question. i know the rear LCAs are different so it wouldn't surprise me to know that the trailing arms are as well. Let us know what you find out.
Old 10-27-2003 | 08:38 AM
Jafro's Avatar
Jafro
I'm made of meat!
I'm also curious. I'm about to pick up a wrecked 93 integra LS, and wonder if the rear brake assembly and control arms would fit on a 92-95 Civic HB. If you find some info on compatibility, please post URL:s here.
Old 10-27-2003 | 10:21 AM
Outxider's Avatar
Outxider
X-Motoring
actually the lcas for the teggys 94-01 gsr/ls r the same as our 92-95 civics coupes/hatches only that, it has a hole for mountin a sway. the itrs r different in design as they mount the strut inside the lca. havin said that, the trailin would seen to fit upon guessin that it would but i cant take chances and need an exact answer. someone has to know this.....
Old 10-27-2003 | 04:01 PM
Outxider's Avatar
Outxider
X-Motoring
YES! its been confirm. 94-01 integra trailing arms are the same as the 92-95 civic si hatches with rear disc brakes. once i get this on, my rims r goin on. :yay:
Old 10-27-2003 | 04:41 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
wOOt
Old 10-27-2003 | 10:50 PM
Jafro's Avatar
Jafro
I'm made of meat!
dang. So a '93 doesn't make the cut. 'guess all I need is the motor and tranny (and seats) from this car. Thanks for the help.
