FS: Integra S2000 antanna conv. kit - $30 shipped
![Default](https://www.honda-acura.net/forums/images/icons/icon1.gif)
I have a S2000 antanna conversion kit - including mast, instructions and everything you need to conv from stock integra antanna to the s2000 antanna.
Got it for a friend, but now he trading in his teg for a S4.
I got the kit online and the mast from honda dealer.
![](http://www.imagestation.com/picture/sraid3/pbe176f5326d4c0d998623bf012c97900/fe3ce557.jpg)
![](http://www.imagestation.com/picture/sraid3/p7285e20a8165ab84dbc3132b28b73bce/fe3ce570.jpg)
So do you think this same kit will work for a 96 Prelude?? Since my antenna is broken now and i have to get a new one this would be a nice way to go, its that i just dont know if it will fit perfectly or will work probably be needed??
I don't know about that. The kit uses the stock integra hole, and the rubber base. If your rubber base and opening is same as integras, then it will fit. As long as the base of the s2000 antanna matches the rubber base, it will be good.
If you can find out that info, then you will know if this kit is good for you.
a sale is pending.
Since so many people are interested, I will find out the contact for the kit maker and let you guys know. This was the second kit I got from the guy, so he is trust worthy.
i got the s2000 mast from honda dealer, so the total price came out to be the rip off price of high $50. I think I saw somewhere that has "aftermarket" oem s2000 mast for a lot cheaper. So the total is probably a little over $40 for both.
I will post back with the info.
Thanks
Wen
Thanks
Wen
Hi guys. I got the money and the antanna is shipped to the person.
I digged through all my emails and found the contact for the kit maker.
b18c510@hotmail.com
His name is chis
The s2000 mast you have to either find it cheap online, or buy a real one from honda.
Good luck.
Wen
b18c510@hotmail.com
His name is chis
Good luck.
Wen
