02 lx 4cyl will not go above 5200 RPMs
Old 06-23-2005, 02:44 PM
02blackaccord
02blackaccord's Avatar
Default 02 lx 4cyl will not go above 5200 RPMs
In my wifes car I was going 40 then got on it to switch lanes, RPM rises then drops. When i was driving i thought it was the trans, but then I started to play with the throttle and realized the engine was losing rpms. At home in neutral parked, the engine was cutting off at 5200, (I don't think thats when the rev limiter kicks in) down to around 4700.
Also, the emission warning lamp came on.
It happend more than once on the way home at differrent speeds. It seems like it is not getting oxygen or fuel.
whats up
02 lx 4 cyl
40k m
Old 06-23-2005, 02:48 PM
02blackaccord
Default Also the emission warning lamp came on.
Old 06-23-2005, 06:37 PM
foot
foot's Avatar
Hard to tell without being able to run some tests on the car. First off, read the DTC in the computer. Sounds like a TPS, maybe.
Old 06-24-2005, 12:22 AM
shreker
shreker's Avatar
check the egr,also check your iacv it could probably be dirty
Old 06-24-2005, 12:50 AM
abexh22
abexh22's Avatar
this happen to me before it was the egr vacumm line it was disconnected but it chould be something esle
Old 06-26-2005, 02:06 PM
blacknight07601
blacknight07601's Avatar
Check/change your oil. If your oil pressure is low VTEC will not engage. ANd usually on the 6th gen 4cyl Accords VTEC can engage anywhere from 4500-4900RPM's
