custom modified exhaust tips
bboy Wesley West
Hey, i hated the look on the exhuast tips so i decided to change them and add a little bling to it. enjoy!
un-Touch'd krew
Uhhh maybe I am missing the point here but cleaning your tips doesn't make it custom...or did I miss part of the post?
bboy Wesley West
thrs a part in the middle that i removed from the stock one. you probably cannot see it in the photo attached but u should know if u have an ex.
its like a part that holds the tip in place or something. you should know what i mean.
un-Touch'd krew
OK I have a DX and have never had the stock exhaust on...might have to go take a look at my wagon to see it
bboy Wesley West
what i did was clamped it down with the tip part upwards. Used a demel w/ cutting bit to make slots (maybe 7 slots), then put the dremel tool into the hole and started to cut upwards. Each of the pieces were cut off and use a grinding bit to ground down the sides so that it is level with the sidewall. Then i bead blasted the inside to remove any carbon or marks from the bit to make it look cleaner. Used mother aluminum/mag polish to make it look pretty. its kinda hard to explain, i wish i had pictures.
and yes i did cut the muffler shorter by about 3 inches, has a different sound also!
