Results 1 to 24 of 24
Thread: How To: Deal With SRS Indicator
  1. #1
    I have a 96 Integra LS that I have started to do a bunch of audio and alarm related activities with. Recently, I added the hatch release option to my Alpine alarm. Problem is, my SRS Indicator light is now on. In order to access the Alpine Alarm to hook up the relay for the hatch, I had to remove the panel right below the steering wheel. Attached to this panel were 2 Sensors. One of the sensors is involved with resetting the Maint. Required Indicator. Now, I do NOT know what the 2nd sensor was for. I unplugged it in order to get the panel entirely out of the way. When I was finished, I plugged it back in, and now the Airbag (SRS) Indicator light is on. I've checked all my fuses (the two fuse boxes), disconnected the battery, but no luck. I've read that the Airbag (SRS) system is equipped so that if the battery is severed in an accident, there is a backup power supply that will still deploy the airbags. I wonder if leaving the battery disconnected for a few hours would help this? I'll try this tommorrow. Does anybody else have any idea as to what could be wrong? From my Haynes manual, it doesn't seem like the mysterious 2nd sensor is at all related to the SRS System. If anyone can help or needs more info. to help, let me know. I know that I could visit an Acura dealership, but I really would prefer to solve this problem myself. Its just that SRS info. is extremely limited no matter where I look. Thanks.
  2. #2
    Rice Rocket BustedLX's Avatar
    Join Date
    Mar 2003
    Location
    Miami, FL
    Posts
    185
    Your going to have to take it to an Acura dealer to have a diagnostic run on the SRS System. They'll charge an hour labor about $67.00 and then they'll let you know what the problem is.
    It is possible you interupted the signal between the bag and the SRS module. That would trigger a trouble code and disable the SRS system. It would need to be reset by the dealer to enable the system and remove the trouble code.
    When they run a diagnostic on the system they can also reset the system for you. Unless they are real a$$holes they won't charge you they'll just inculded in the one hour labor.
    Just make sure you haven't unplugged any inertia switches or any yellow loomed harnesses. If you have, plug everything back together and go to the dealer.
    Good Luck
  3. #3
    SRS
    Yes, my unplugging the fuse did cause the light to come on. After a lot of research, I managed to find a way to reset the SRS. There were NOT many sites that stated how to reset the SRS. The few that existed lacked details. I however, have my own site which I have posted how to reset the SRS IF you have unplugged a harness or fuse involved with your airbag system. Visit
    http://www.geocities.com/myintegra96/srs.html[/URL]
    for the reset instructions. BELIEVE me, it works. I did it on my 96 Integra and am pleased to say that it worked. ANY questions, IM me or email me.
    GOOD Luck everyone
  4. #4
    Hi Everyone,
    Several years ago I researched how to reset the SRS light on my 96 Integra LS. It took forever for me to find, but I eventually found and figured it out. At that time, I made a website with pictures and directions. Since then, my site has had over 2,000 visitors and I have received numerous emails and questions through AIM.
    I just finished updating the site with more pictures and Adobe Acrobat PDF files that can be downloaded and printed, that give the directions. I'd like to know what everyone thinks. Also, if you used these directions on your car and they worked for you, let me know.
    The site is:
    Thanks.
  5. #5
    Registered User foot's Avatar
    Join Date
    Jun 2005
    Posts
    505
    When the SRS control unit senses low voltage the SRS light comes on. If you change your battery, the SRS light will come on.
  6. #6
    I've NEVER seen my SRS light come on due to changing or disconnecting the battery. I have also had my car with low voltage (ie, I had to jump it) and the SRS has never come one. I've had my car 3 years now and have done a lot of work and tinkering with it, and from what I understand, the SRS light only comes on if there is a malfunction in one of the SRS components or if you pull the fuse.
  7. #7
    Join Date
    Jul 2005
    Posts
    SRS Light on 95 Accord
    My wife was in an accident last winter, and the people who fixed the car didn't put the steering wheel on straight. Last night, I took the steering wheel apart and reinstalled it correctly. The SRS light did not come on last night, but did come on this morning and now will not shut off. I don't know if anyone has done this before, but will the instructions listed here reset the light?
  8. #8
    i think the directions will work for an accord. If not, the light will just stay on and you'll have to have a mechanic or dealership take a look at it. See if you can find the SRS connector found in the dummy harness.
  9. #9
    Registered User C2daIzZle's Avatar
    Join Date
    Sep 2005
    Posts
    20
    they'll work.
  10. #10
    Join Date
    Nov 2005
    Posts
    2
    SRS light extinguishes Works on Acura 3.2cl
    I have an Acura 3.2cl and the SRS light illuminated for what seems no apparent reason and i needed a quick reset. After reading Joshers post i tried it. To my great satisfaction the fix works. So to others i say save your cash. Its not hard and I believe unless you crashed your car its most likely a nuissance fault. Just out of curiosity to the people who do go to the dealer what was the eventual fix?
  11. #11
    Join Date
    Jan 2005
    Posts
    115
    if i try these instructions, and the light stays on - does that mean there is actually a problem with the airbags?
    ~96 Civic LX~
    106 hp, hell yeah!
  12. #12
    Join Date
    Apr 2006
    Posts
    Clearing Honda Accord SRS Codes
    I try this on my 2000 haonda accord V6 and it work it is very simple.
    thank's to http://www.geocities.com/myintegra96/srs.html
  13. #13
    Vivere est Cogitare TheOtherDave™'s Avatar
    Join Date
    Nov 2002
    Location
    The Left Lane
    Posts
    51,756
    Good to hear we've got a working solution..
    I'll add a link to the Integra FAQ Thread.
    :: david - supermod
    :: PSN - TheOtherDave-tm
    :: HAN Integra FAQ: Utterly antique, but still useful... sort of.
  14. #14
    Join Date
    Jul 2003
    Location
    South Carolina
    Posts
    13
    I just used Josher's procedure on my 2001 Accord LX V6 and it worked great.
    The plug is located under the driver side dash, behind the fuse compartment. There are two yellow plugs, it's the smaller one on top. The plug has a green wire and a black wire with a green trace.
    There is also a Warranty Extension for SRS lights on various Hondas, it is number 06-009 dated March 14, 2006.
  15. #15
    Just an FYI - I know my geocities website with the reset instructions has had a long history of "bandwith exceeded" where the site has gone down. I finally redid the site today with all images linked from photobucket. This should solve the site's problems. Thanks.
  16. #16
    Join Date
    Jul 2005
    Posts
    Dude, thanks for the instruction on the SRS reset. I am so glad for this site and for people like you that can share this kind of info.
  17. #17
    Mcgyver
    Join Date
    Aug 2007
    Location
    Davis California
    Posts
    114
    Turbonics, if the steering wheel was not installed properly your clock spin is damaged. That is the part that looks like a plastic donut with an SRS sticker on it and a ribbon wire coming out of it. This is like a $30 part at a pick'n'pull type junkyard, or 220 at a dealer. You have to replace it if it maked or makes a squeaking sound. Your bags will not work. So replace then reset and you are good to go.
  18. #18
    Join Date
    May 2008
    Posts
    works like a charm.
    thanks
  19. #19
    Join Date
    Dec 2009
    Location
    VA
    Posts
    My SRS light was on when I bought my Integra 3 years ago. I was told that an after market steering wheel was put on at some point, then the stock was put back on before I bought the car. My mechanic tried to reset it with some sortof scanner but it didnt work. I talked to another mechanic and he said the light could be on due to when the stock wheel was put back on, sometimes the clock coil gets moved and that will do it. I havent tried what Josher had said, but if the mechanic cant reset it, would it maybe still work? I havent tried it because I really dont know what Im doing. Has anyone else heard of a clock coil when the steering wheel gets removed and put back on?
  20. #20
    Join Date
    Jul 2010
    Posts
    4
    If your SRS/AIrbag light is on, or your airbag is faulty and you have a code error, this website helped out alot: Cartipsntricks.com It has esay tutorials and video on how to reset yor SRS/Airbag light, and fix your airbags with a resistor(very easy to do, helped me alot , try it out).
  21. #21
    Join Date
    Mar 2012
    Location
    bakersfield, ca
    Posts
    I have an acura integra 95. I put a system in it and now when I bump my system , my SRS light comes on and makes my car shake. It even turned off. I had to power off my radio then turn my car back on.
    Someone told me that if I get a compasitor it wont drain my battery and my SRS light will not turn on.
  22. #22
    Join Date
    Apr 2012
    Location
    USA
    Posts
    5
    thats an nice stuff it would really help me alot it makes the sens.
  23. #23
    Join Date
    Apr 2012
    Location
    United States
    Posts
    4
    Hey Josher...
    I hv bought a ACURA 3.2CL & has that SRS button on.. geocities is no more active..
    Can u plz help me with the solution...
    Thanks!!!
  24. #24
    Join Date
    Jun 2012
    Location
    New Jersey
    Posts
    HI everyone - I have a 1996 acura integra and I noticed that the SRS light was on the other day, and stayed on for most of the day, and now it turned off. I have never seen that light on before (and I am the original owner). What do you think? Should I still get it checked it out? Also, my ABS light is on, but that's been on for a while now....Thank you.
  25. #24
    Honda-Acura
    Honda S2000
    Honda-Acura
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Search Engine Optimization by vBSEO 3.5.2
